cam sensor
GRANNYCLOWN
A friend has a 1997 Dodge Caravan that the diagnostics says that the cam sensor needs to be replaced. He purchased the sensor, can you tell me where it is located?
Jun 7, 2007 at 12:49 AM
E40WATER12
  • 522 POSTS
Should be in the rear area on the passanger side near the valve cover meets the cyl hd, Should have a wiring harness sticking out, 1 bolt that holds it into place.
good Luck.
Jun 7, 2007 at 7:41 PM
