brakelines 96 dodge caravan
MIRAGE5058
I have a 96 dodge caravan i bought it has a 3.3 loaded,my problem is the person i bought it from tried to repair the brakelines hiself,in doing so he removed all the lines going to abs unit,i need a diagram of some sort to replace the lines in the correct order to abs unit,have no idea were they go and they right way to connect them to abs,Any help would be greatly appreciated,Thanks
Aug 20, 2007 at 5:20 PM
SERVICE WRITER
  • 9,123 POSTS
Ouch, I'm not sure about the 96s but the 97s had braided stainless steel flex sections that allowed the lines to be in a postion that prevent the fluid from boiling over due to the location close to the exhaust.
The dealer should have the lines pre-bent and with flex piece.
Feb 25, 2021 at 12:38 AM
MIRAGE5058
Thanks after looking at it today i did find pieces of the old brake line it was flex line i found them in the back on the floor but they are ruined,the kid took all the lines off the vehicle,front and back,the only good thing is he got the old lines off at each point without destorying anything else,on the abs unit it has four locations for four lines do the front lines go to the first two on the left of the abs unit and the back two,the last two on the right or vic versa,thanks
SERVICE WRITER
  • 9,123 POSTS
I'll try to find out, I had one similiar in the shop, but the phone stated ringing and I rushed the pic :roll: . But I'll see what I can find, there is another on in the lot :cry: I can crawl under.
https://images.2carpros.com/forum/automotive_pictures/30961_P8210007_1.jpg
MIRAGE5058
Thank You,the image is a big help,I surely appreciate all your help maybe i can get this vehicle done now that i see how i am suppose to connect the lines,I only paid 150.00 for the van and it runs and looks great,so its worth fixing,has double sliding doors and its loaded.I was afraid i was going to wind up putting 1000 bucks in it.I thank you again very much.You"ve been a great help,John
SERVICE WRITER
  • 9,123 POSTS
Glad it works for you, looks pretty rough to me. I couldn't get inder the other van today, too wet. It you need me to, I will, let me know. If I would have seen "have donated", I probably would have guilted myself into it. Glad we could save you some $$$.
