How do you bleed the brakes on a 93 Dodge Caravan? Any special tools needed?
May 24, 2007 at 3:47 AM
Bleed the brakes with a wrench that fits the bleeder screws, fresh brake fluid, and a helper. Pump the pedal 3 to 4 times, hold it down, open the bleeder until fluid stops, then close it and repeat. Work right rear, left rear, right front, then left front, and keep the master cylinder from running dry.
The owner asked how to bleed the brakes on a 1993 Dodge Caravan and whether special tools are needed. The expert said a fitting wrench, brake fluid, and a helper are enough: pump the pedal several times, hold it, open each bleeder until fluid stops, then tighten and repeat. Bleed right rear, left rear, right front, then left front, checking the fluid level so the master cylinder does not run dry.
