1990 Dodge Caravan have very little brakes after changing b
KAIYA32
  • 1990 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 150,000 MILES
Changed brake line on front right brake and bleed front brakes however front right brake would not go to floor only letting out sqeaks of air and I still have brake light on and very little brakes
Thursday, October 30th, 2008 AT 9:48 AM
  • 109,885 POSTS
First, when you bleed the brakes, start at the wheel furthest from the master cylender and work your way to the closest. Next, which brake line did you replace? Was the master cylender allowed to drain while you worked on the brake line? Finally, where are you bleeding the brake system from? Is it the caliper or the line you replaced? Did you replace front brakes?
Sunday, February 21st, 2021 AT 12:43 PM
