Hi, I have a 1999 Dodge Caravan 158k, V6 3.0L. For the past few months there has been a squealing sound coming from what appears to be a belt. This only happens when the heat or A/C is on, which I was told suspects the fan belt as being the culprit. When I turn on the heat or A/C and look at the alternator area when it's squealing, the belts appear to be sticking every so often, then it starts squealing for a little while. If the heat or A/C is off, this does not happen. Any ideas on how I can fix this problem (As you could probably tell I'm a rookie with mechanical repair)?
Jun 1, 2007 at 12:04 AM
