I have the same problem. I looked in the power distribution center (under the hood, near the battery), and found a fuse for the power outlets, but it was good, and replacing it didn't help. (If you haven't found it, on my 2000 Ply Voyager, the power distribution center is on the driver side. Remove the cover by pulling the two latches, and the diagram is on the inside of the lid. You should be able to find the fuse from that.)
I seem to recall this happening before, and I had to take it to the shop, but the repair seemed extremely simple. I wonder if I can't do it myself, if I knew what to do! Anybody have any clues?
Thanks
Jan 16, 2006 at 9:53 AM
