1998 Dodge Caravan Belt Breaks After Tensioner
RC560SL
I recently had the tensioner replaced on my dodge van. However, the old belt was not replaced at the same time. The tech said it looked fine to him but as soon as I drove off the lot and cranked up the a/c it broke. Now I have been desperately trying to schedule an appointment to get the belt replaced. Aren't the belts supposed to replaced rather than stressed and put back on?? Keep in mind I live in Florida and at this time of the year it averages about 90 degrees outside.
May 21, 2006 at 6:00 AM
VANDRAGON
  • 298 POSTS
any fool that does not replace the belt with new tensioner should be flogged. odds are he didn't even replace the tensioner, or he put the belt back on wrong. if he will not fix it, take it to another shop and then take him to small claims court.
May 22, 2006 at 7:06 AM
Suggested Repair
Replace the drive belt with a new one whenever the tensioner is replaced, and have another shop verify that the tensioner was actually replaced and the belt was routed correctly. If the original shop will not correct the work, use another shop and consider small claims court.
Conversation Summary
The owner of a 1998 Dodge Caravan had the belt tensioner replaced, but the old belt was reused. The belt broke shortly after leaving the shop when the air conditioning was turned on in hot weather. The expert said a new belt should be installed with a new tensioner, questioned whether the tensioner was replaced or the belt was installed incorrectly, and advised taking the van to another shop and pursuing small claims if the original shop will not fix it.
