3.3L V6 with 136,000 miles. Van has been good. Recently I purchased a device from Harbor Freight which was supposed to retain computer settings when battery is disconnected. I used it to do work on a starter which failed intermittently. That trouble was easy since it was only a loose connection. When I reconnected the battery the charge light indicator stays on. I have had the alternator checked good twice. Sometimes it will charge after reassembly but only at about 13.4 volts with battery already at 13.o after charger time. Then, it will fail within 5 minutes. Possible PCM problem? Any input would be appreicited.
Mar 25, 2007 at 8:02 AM
