97 Dodge Caravan 4cyl. Dies out w/rough idle
TIP808
My 97 Caravan, Sometimes dies out while running or at a stop light. It has a slightly rough idle. It eats gas like a V8. I changed the idler sensor and still, same problem... :cry:
Mar 15, 2006 at 11:21 AM
VANDRAGON
  • 298 POSTS
sounds like weak spark or it is getting too much gas.
when was the last time you changed your air filter?
Mar 18, 2006 at 3:09 AM
DANDAMANN
  • 5 POSTS
I had the same problem all i had to do was replace my ignation coil if you can with the car running pull the sparkplug wires off the coil one at a time but use a rag so u dont get shocked :shock: and see if you have spark u can here the difference if thats it cost only $70.00 to fix
Mar 20, 2006 at 10:29 AM
