97 Dodge Caravan 4cyl. Dies out w/rough idle
TIP808
  • 1997 DODGE CARAVAN
My 97 Caravan, Sometimes dies out while running or at a stop light. It has a slightly rough idle. It eats gas like a V8. I changed the idler sensor and still, same problem. :Cry:
Wednesday, March 15th, 2006 AT 7:21 PM
VANDRAGON
  • 298 POSTS
Sounds like weak spark or it is getting too much gas.
When was the last time you changed your air filter?
Saturday, March 18th, 2006 AT 11:09 AM
DANDAMANN
  • 5 POSTS
I had the same problem all I had to do was replace my ignation coil if you can with the car running pull the sparkplug wires off the coil one at a time but use a rag so u dont get shocked :shock: and see if you have spark u can here the difference if thats it cost only $70.00 to fix
Monday, March 20th, 2006 AT 6:29 PM
