I have a 93 Dodge Caravan ES 195,000 miles.The person we bought it from said they put $2500.00 into the transmission.I have a transmission problem.If you put the shifter in "L"(1st gear).The transmission pulls hard in reverse & 1st gear,in other words it works correctly.When I put the shifter in the "3 or D" position it will not shift up into the upper gears.It shifts out of 1st & won't go into 2nd,like it is stuck in the middle,It does not grind, it just slips & will not pull itself.I have changed the transmission fluid & filter,found alot of metallic shavings(like metallic paint) & the transmission fluid had black in it,but was not burned(did not look like motor oil).I'm guessing transmission is junk,but hoping you might have some other suggestions to try.Hope you can help.Thanks for any suggestions.
David
David
Sep 10, 2006 at 1:41 PM
