93 DODGE CARAVAN DIED
MET5673
93 DODGE CARAVAN 3.0L JUST DIED GOING DOWN THE ROAD. EVERYTHING ELSE WORKS, JUST NO FIRE FROM THE COIL. TESTED COIL(GOOD),WIRES(GOOD), RELAYS(GOOD), REPLACED SBEC, GETTING VOLTAGE TO COIL, JUST WHEN YOU PLUG THE COIL IN AND TURN THE ENGINE OVER IT''S NOT FIRING THROUGH THE COIL. 6 WEEK PROBLEM AND CAN'T AFFORD TO TAKE IT TO A SHOP. HELP PLEASE!
Feb 15, 2007 at 9:37 AM
MIKE H R
  • 3,094 POSTS
try something, use a little starting fluid in the intake and see if it starts?
Mar 6, 2007 at 7:21 AM
RETIREDAUTO
  • 46 POSTS
i'm a little rusty i can't remember wheather this has a single coil or a pack, if it has a single coil. and are you sure it has no spark,if sure. try un plug coil power wire with a test light across terminals crank eng. see if light flashes,if so suspect coil,if no suspect ign.pick-up coil, have tou got any trouble codes to start with??, let me know
Mar 6, 2007 at 10:37 AM
BEBOT
try cleaning or replaceing your spark plugs they may need to be gapped or replaced
Mar 7, 2007 at 3:56 AM
MIKE H R
  • 3,094 POSTS
see if this will help you mike
https://images.2carpros.com/forum/automotive_pictures/54223_coil_res_dodge_caravan_1.jpg
Mar 8, 2007 at 7:43 AM
