93 caravan, Fan will not turn on, runs hot
BLUE SAILOR
I have a 93 Dodge Caravan 140K miles 3.3 engine. The Radiator fan stopped working and the van ran hot. I have changed the temperature switch and the sensor both located near the thermostat. I have replaced the fan with a brand new one. And changed the fan relay that I was told was on the passenger side fender above the strut. Still nothing. I hear that there is another switch. Could you tell me where it is and what is it called, or give me some indication on what else can I do
Thanks
Jul 26, 2006 at 6:01 AM
CARAVANOGRE67
  • 22 POSTS
if you cant find the last switch you could always run a toggle switch to it and switch it on when temperature starts to get hot. you dont need a fan after 50kmh as the air is running fast enough through the rad to cool it enough.
i will look in my book and see if i can find that last switch and if i can find it i will get back to you
Aug 9, 2006 at 4:23 PM
