2008 Dodge Caravan noise in eaither the altanator or tenion
2008 DODGE CARAVAN
NKSMITH2001
Noises problem
2008 Dodge Caravan 6 cyl Two Wheel Drive Automatic
how do i find out which is making the noise and I need to know how to remove the serpintine belt
Jul 3, 2010 at 7:04 AM
  • 110,244 POSTS
You have the right idea. Remove the belt and spin each pulley to see where the noise is coming from.
As far as removing the belt, there is an automatic tensionier on it. It rides on a pivot. Using a wrench, you simply turn the tensionier on its pivot in the direction to loosten it from the belt.
Let me know if you have other questions
Jul 3, 2010 at 5:20 PM
