2008 Dodge Caravan brake rotor removal
2008 DODGE CARAVAN
26,000 MILES • 6 CYL • FWD • AUTOMATIC
JERRYCAHILL6
Hi! I'm able to remove the caliper, the brake pads, and the carrier, but I'm unable to remove the rotors themselves. I don't see any set screws to unscrew. Can you please tell me how to remove these Grand Caravan rotors? My engine size is the 3.8 liter engine. Thank you for your help.
Sincerely,
Jerry
May 11, 2010 at 5:02 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Once the brake caliper and adapter bracket have been removed there should be clips retaining the rotor to the wheel studs. If so, remove those. If not, the rotor should slide off of the hub and bearing. If it is difficult, try banging on it between the studs with a rubber mallet. The rotors can sometimes become stuck due to brake heat.
Mar 1, 2021 at 2:20 AM
