2005 Dodge Caravan Front rotor and pad replacement
65,000 MILES • 6 CYL • FWD • AUTOMATIC
NEW_TO_DODGE
  • 35 POSTS
Hopefully a quick question. 2005 Grand Caravan SE with 65000 miles on the 3.3L V6. Are the front rotors held on by the calipers or pressed to the hub? Also, are the pads the type with or without hooks?
Mar 21, 2008 at 11:19 AM
BMRFIXIT
  • 19,053 POSTS
no just remove the caliper and the rotors
ez
Mar 21, 2008 at 11:27 AM
NEW_TO_DODGE
  • 35 POSTS
Thanks very much. I appreciate the fast response. Would you happen to know if the pads have hooks or not. When I went to get them, I was asked and wasn't sure.
Mar 21, 2008 at 11:34 AM
BMRFIXIT
  • 19,053 POSTS
you have to pull the tire and check
I cant answer this for you sorry !
they made both and the only way to find out is by pulling the tire and checking
good luck
Mar 21, 2008 at 11:43 AM
NEW_TO_DODGE
  • 35 POSTS
Thanks for your help...I'll do that in the morning
Mar 21, 2008 at 11:45 AM
NEW_TO_DODGE
  • 35 POSTS
Just quick follow up if anyone is interested...
Changing the rotors and pads are easy enough, but make sure before you start you have a 7mm hex allen wrench handy. You will need it to remove the caliper bolts.
Also, have a decent adjustable wrench handy to loosen the caliper bracket bolts so you can get the rotor off.
Mar 24, 2008 at 12:14 PM
