2007 Dodge Caravan How to access the pulley to remove &
2007 DODGE CARAVAN
55,000 MILES • 6 CYL • FWD • AUTOMATIC
PERERAK
[img:824c80c4e1]http://www.2carpros.com/forum/automotive_pictures/548542_Idler_Pulley_1.jpg[/img:824c80c4e1]
Your response to the above question tells me how to remove the pulley & replace ,but it does not address the issue of accessing the pulley which is really the problem . May be I should have been a little more explicit . A donation of $10.00 was made last time.
Jul 11, 2010 at 4:00 PM
2CARPRO JACK
  • CAR REPAIR CONTRIBUTOR
  • 11,533 POSTS
You may have posted twice, so I didnt get to see he other reply.Try removing the upper motor mount while the engine is supported from below with a block of wood on a floorjack.You can lift the engine a little bit once the mount is out of the way to get a little more room.These vehicles are very tight , so you just have to remove things til you have the room you need.
Jul 13, 2010 at 8:15 AM
