2007 Dodge Caravan Drum In Hat Noise
30,000 MILES • 6 CYL • 2WD • AUTOMATIC
X94TIMBERSTAR
So I just did the rear brakes on my 07 dodge caravan, and it makes noises when I go around corners at low speeds. New Pads and New rotors were installed It looks like there is a Star screw under the rotor to make the drum diamtere smaller. Should I adjust this?
Sep 14, 2009 at 11:57 AM
CARADIODOC
  • 34,413 POSTS
That star wheel and shoes are the parking brake. They only need to be adjusted if the parking brake pedal goes too far to the floor.
There are a whole bunch of things professionals do during a brake job to prevent these noises from occurring. Most notably, did you apply a thin coat of high-temperature grease to the hub where the rotor sits on it? Did you remove the sharp edge on the leading and trailing edges of the new pads with a file or sandpaper? Did you use a torque wrench to carefully tighten the lug nuts equally? Failure to do so will cause the new rotors to warp from the heating and cooling cycles and the uneven clamping forces.
The caliper mounting bolts must be straight and free of rust. They must be lubricated too. There should also be a light coat of grease between the pad backing plates and the caliper contact points. This will reduce their tendency to squeal, but not a grinding noise.
One final point to be aware of is if you have custom wheels. With new pads, the caliper is moved outboard from the vehicle the farthest it will ever be. In rare cases, the caliper housing could contact the inside of the wheel. This will cause a grinding noise when the wheel flexes during cornering.
caradiodoc
Sep 14, 2009 at 5:31 PM
X94TIMBERSTAR
Still scraping sound when cornering. Goes away when applying brakes.
I did sand the sharp edge off the pads where it transistions from the flat surface to the angle.
I wonder If i did not sand enough??
I lubed as MFG directions (Caliper Pins, Pad holder spots,Hub too.)
I always use the star pattern and a torque wrench. (Former Tire buster in a previous life).
The Parts I used are OEM Bendix Pads (Ceramic) and rotors
No custom wheels
Any ideas?? Thanks for the great help
Sep 15, 2009 at 8:30 AM
CARADIODOC
  • 34,413 POSTS
Should have mentioned your previous experience so I wouldn't insult you with trivial stuff.
I found you don't have to remove much of the sharp edges on the linings; just enough to remove the "finger nails on the blackboard" effect during the break-in period. I started just dragging them on the concrete floor a little to remove the edge. That prevents squeal when the brakes are applied, not a scraping sound.
Check for rust buildup on, or a bent backing plate, although, as I recall, I think they're quite thick and hard to bend. Look for debris in the groove of the drum that goes around the lip of the backing plate. Shiny spots will be a "witness mark" if that's the noise source.
If both wheels make the noise, suspect an issue with things like the rotors are just a little bigger in diameter or the linings are glued just a little off-center or are larger than the originals. Noises from these things will go away over time.
I don't think this applies, but I saw a fellow once install the parking brake strut rod upside down and it rubbed on the hub of the drum. That was on a drum brake, not what you have. I also once had a scraping problem after the caliper wasn't fully seated when I installed the mounting bolts. The wheel went on fine, but the caliper would rise up and hit the wheel when braking. Oops!
Also, don't overlook the fact that quality linings are rather hard and will make a scraping sound until they're warmed up. That's normal, and is one reason there's so much trouble with brake squeal these days.
If all else fails, I used a tool called a chassis ear. It is six microphones you can clip on various places, then listen with headphones while you drive the car. It's used at the Chrysler dealerships, and we had two at my community college. The new models have four wireless mics and two with wires. The older models had wires on all the mics. Matco has them available, and I'd bet so do Mac, Snapon, and Cornwell for around 100 bucks.
Let me know if you find something.
caradiodoc
Sep 15, 2009 at 8:53 AM
X94TIMBERSTAR
I appreciate starting from a beginner viewpoint. That's what I do whenever anybody ask me a consulting question. Sometimes it offends "the expert" who asking the question, but then I think Why are we talking then
I did a real lite sand the first time, and noise went away on the left, I need to touch up the right and as it is still making the sound. I think the parts I got didn;t have enough angle on them.
It's gotta be this because the noise goes away when my brakes are applied in the corner. And everything runs great when going in a straight line.
Thanks for your help
Sep 15, 2009 at 9:31 AM
