2007 Dodge Caravan Compressor not working
STEWART ADAMS
Air Conditioning problem
2007 Dodge Caravan 6 cyl Front Wheel Drive Automatic
I have found my recharging port for my A/C, but now I notice the problem (at least in part) is that the compressor isn't even turning on. Is there a dedicated fuse for this or do I potentionally have bigger problems? I was thinking the system just needed to be charged but while attempting to do so, realized the compressor never came on whether in A/C mode or defrost. ???? Help!
May 26, 2010 at 10:08 PM
  • 75,988 POSTS
Run a jumper wire from the battery to the clutch if it comes on check the AC clutch relay, cycling switch and pressure switch-don't come on the clutch is defective-now if the clutch engages the compressor and it won't come on the compressor is locked-up
May 26, 2010 at 11:01 PM
