2007 Dodge Caravan Buzzing noice front end
51,000 MILES • 6 CYL • FWD • AUTOMATIC
BLACKCANDT
After driving a while the van will start to make a buzzing sound. Almost like a RF noice I once heard. Our dvd player recently broke. Not sure if that would cause it or not. Does it in all gears and only after its been driven for an extended period of time.
Jun 19, 2010 at 3:36 PM
  • 110,248 POSTS
Does the noise sound like it's coming from the transmission?
Jun 19, 2010 at 4:05 PM
BLACKCANDT
It is possible. I had thought before it could be coming from there.
Jun 19, 2010 at 4:18 PM
BLACKCANDT
It does do it occasionaly when stopped as well but mostly after driven for a while. It sounds like an electrical type of buzzing but I have thought at times it was coming from the transmission
Jun 19, 2010 at 4:25 PM
  • 110,248 POSTS
If the noise is there when you stop, I wonder if it could be one of the accessories such as a water pump, alternator... Try this. Remove the serp belt and start the engine to see if the sound is gone. NOTE: Only run the engine a few seconds with the belt off. It will overheat if you run it too long.
Jun 19, 2010 at 5:08 PM
