2006 Dodge Caravan windshield wipers
118,000 MILES • 6 CYL • FWD • AUTOMATIC
BRANX4
My wipers appear to be out of sync.
they work OK for a couple of sweeps then the drivers side blade seems to override and get tangled up with the passenger side blade. This is now my 3rd broken blade in the last couple of months. Can the moter be adjusted? Do I need a new motor? How much (approx) would the repair cost?
Thanks.
May 31, 2010 at 7:21 AM
  • 110,248 POSTS
I believe you just have a loose wiper arm. In 06, the arm bolted to the mount. There is a hinged cover where it attaches. Open it and check to see if the bolt is loose. If it isn't, then remove the arm and check the threads to make sure they are not stripped. Other than that, you need to remove the cowl at the base of the windshield to see if there is a problem with the linkage. As far as the motor, there is only one and it runs both blades. If they are working, the motor is fine.
Jun 4, 2010 at 5:04 AM
