wheel nut & stud replacement
10,000 MILES • 6 CYL • FWD • AUTOMATIC
KOOLTETE
broke a few studs which and need your expertise to how to have this done. In the meantime Im stuck at trying to remove the drum. what is the trick to its removal The broken studs are on the passenger rear.
Dec 10, 2009 at 2:42 AM
CH112063
  • 1,320 POSTS
The way it comes off is to back off the self adjuster wheel, it is not very easy, I know. They make a drum puller for this problem. The studs just hammer out, and you can use a nut and a smaller lug nut to pull it into the hub. The larger nut goes over the new stud(larger then the threads, and use a lug nut to turn it in, it pulls the stud in place.
Here are two videos that will help you out.
https://youtu.be/LSZ8P0wrQX8
and
https://youtu.be/UV0kfP17Co0
Please run down these guides and report back
Cheers
Dec 10, 2009 at 11:33 AM
