2006 Dodge Caravan water pump
65,000 MILES • 6 CYL • FWD • AUTOMATIC
WINTERCAR01
How to change waterpump on 2006 dodge grand caravan - 3.8 L V6
Nov 22, 2009 at 2:06 AM
CH112063
  • 1,320 POSTS
Disconnect negative batt. terminal. Drain coolant. You must remove the belt, removing the shield that allows access first. The belt slips off, after releasing the tension, at the tensioner pulley. First, remove the water pump pulley, let it hang there turning it so you can access the water pump bolts. Clean both surfaces good. re-install. If you need help or further instructions, just ask. ok
Nov 23, 2009 at 1:01 PM
