2006 Dodge Caravan SXT, 3.3L v6 engine, 24000 miles
MGMM1
Weve recently had the front disk brakes serviced after less than a year of ownership. Weve been told by a friend to have the dealer check the master cylinder as there might be an uneven distribution to the front discs. The dealer tells us that this is a maintenance item. Just recently were hearing a single sharp knocking metallic sound when we sharply apply the brakes even at low speed. We also have a similar single knocking metallic sound when we shift in to reverse while parked.
Do you recongnize a chronic problem? Also, have these cars had a cronic problem with the master cylinder? Any help with our problem?
Feb 20, 2007 at 3:54 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like either a motor mount problem or suspension problem. Can you determine which side the noise is coming from? Take it back.... Make them replace parts til its fixed..... You bought a new car and shouldnt have these problems so soon
Feb 21, 2007 at 12:09 AM
