2006 Dodge Caravan Rear Wiper
ZANMELY
Electrical problem
2006 Dodge Caravan 6 cyl Front Wheel Drive Automatic
the rear wiper start working as soon i put the ignition on and the only way that turn off is if i remove the fuse but when i do that the radio dont work
Apr 2, 2010 at 8:58 AM
CH112063
  • 1,320 POSTS
I was looking at one like yours. There is an accessories relay you should be able to remove to turn the power off to the rear wiper, see if it's a stuck relay by swapping it with another. It's in the power center in the engine compartment. It is controlled by the front module which gets a signal from the body computer. The BCM gets it's signal from the rear switch module. And the most likely problem is the rear wiper module, it contains the wiper park switch internally so the rear wiper doesn't stop in the middle of it's swing. ok? All modules, but maybe that relay or switch could be bad. The dealer has the DRBIII which makes checking it fairly easy. Fairly. Not real easy.
Apr 4, 2010 at 12:46 PM
