2006 Dodge Caravan rack and pinion/brakes
13,000 MILES • 6 CYL • 2WD • AUTOMATIC
BLANCAGIRL
I went in for an oil change and mentioned a grindind noise. They said it was the rack and pinion needed to be replaced and I also needed front brakes. Would the defective rack and pinion have affected my brakes?(front ones by the way)
Jun 13, 2008 at 1:42 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:a0e0af852e="blancagirl"]Steering problem
2006 Dodge Caravan 6 cyl Two Wheel Drive Automatic 13000 miles
I went in for an oil change and mentioned a grindind noise. They said it was the rack and pinion needed to be replaced and I also needed front brakes. Would the defective rack and pinion have affected my brakes?(front ones by the way)[/quote:a0e0af852e]
If it only has 13 thousand miles on it then I would call the Dealer it should still be under Warrantee.
Oh, and no it shouldn't affect the brakes...
Jun 15, 2008 at 2:50 PM
