2006 Dodge Caravan power sliding door lock
64,000 MILES • 6 CYL • FWD • AUTOMATIC
DEREKLEVI
the pass rear door will not open with the key fob nor the drivers switch. if you open it manually the for ways still flash like normal. everything else works fine
Aug 13, 2010 at 1:39 PM
  • 110,248 POSTS
It sounds like a bad solenoid. What you need to do is remove the door panel, locate the locking solenoid and check to see if it is getting power. If it is, replace the solenoid.
Here are directions:
https://www.2carpros.com/how_to/door_lock.htm
Let me know what you find. It is either a loose connection or the solenoid is bad.
Aug 14, 2010 at 3:45 PM
