2006 Dodge Caravan no start
68,234 MILES • 6 CYL • 2WD • AUTOMATIC
DMOR9532
  • 8 POSTS
van was running fine on trip shut it off , went to restart and just cranks. no codes set, has good fuel pressure, it has spark for 1 to 2 seconds then no spark. 3.3 engine
Apr 5, 2009 at 4:35 AM
PEAR69
  • 1,482 POSTS
1 - If there is an intermittent spark, check for shorts in the coil driver (or drivers) wiring. 2 - Test the coils for proper resistance. 3 - The crank and cam sensors tells the PCM which driver to fire, if all the wires are good and the coils are good then there could be a problem with the PCM.
Apr 5, 2009 at 4:19 PM
