2006 Dodge Caravan lifter noise
RVDNROCK
Noises problem
2006 Dodge Caravan 6 cyl Front Wheel Drive Automatic 93,ooo miles
my lifters are clicking like a sewing machine. I put some rislone in and let the engine run for an hour and i still have noise, and the oil is newly changed before i added the rislone, is there anything else i can do besides have the mechanic charge me $1500 or more
Dec 19, 2008 at 9:20 AM
  • 110,251 POSTS
Hi:
There really isn't anything else to do other than have the lifters adjusted or replaced. However, if your engine is a 3.3L, have the mechanic check the heads (rear one in particular) for broken rocker towers. There were a bad run on a few of them.
Dec 19, 2008 at 3:37 PM
RVDNROCK
i was told t run the van for a couple of days and see what happens and the rislone should work. if not will running the van hurt me more in the long run, or can i just run and wait till i have money to replace the lifters
Dec 21, 2008 at 1:27 AM
  • 110,251 POSTS
Hi:
It's hard for me to say because I'm not there to actually hear how bad they are. It they are'nt too bad, it shouldn't hurt but I don't want to say.
Listen, I don't think it would cost much, so take the van to a mechanic and have them check the oil pressure with a gauge. If the pressure is good, I'll feel a lot better. You should have around 10 PSI at idle and increase with RPM's. It should max at around 60 PSI.
Let me know what you find.
Dec 21, 2008 at 12:48 PM
