Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Caravan
Engine Cooling
Water Pump
Leak
2006 Dodge Caravan leaking water pump
2006 DODGE CARAVAN
71,000 MILES • 4 CYL • 2WD • AUTOMATIC
TVAWTER
MEMBER
1 POST
What would a reasonable estimate be to replace a leaky water pump?
Apr 23, 2009 at 10:56 AM
BMRFIXIT
Experienced Mechanic
Four cylinders water pump is driven by timing belt
I would suggest replacing the timing belt too
at about $500
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Apr 23, 2009 at 12:01 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
