2006 Dodge Caravan Error Codes
79,000 MILES • 6 CYL • FWD • AUTOMATIC
AMMOMAN
I am getting an error code P0406- exhaust gas recirculationsensor A circuit high, on my van and I was wondering what needs to be done to fix this problem.
Dec 11, 2008 at 11:00 PM
ZACKMAN
  • 4,202 POSTS
That is your EGR valve solenoid. Try removing your EGR valve (solenoid is a part of it) and try cleaning all the carbon buildup as much as you can, and re-install. Reset the PCM. If the codes comes back, you will have to replace the EGR valve.
Dec 12, 2008 at 4:32 PM
