2006 Dodge Caravan cv joint
JIFFYMAN
Drive Train Axles Bearings problem
2006 Dodge Caravan 4 cyl Front Wheel Drive Automatic
i had helped replace the driver side cv joint on a dodge caravan. after replacing it it drove down the street where we had been working on it and it did the same thing it did before we had rplaced it. it made a grinding noise going from rev into park
Aug 1, 2009 at 2:07 PM
  • 31,937 POSTS
Hi there,
This will not be a CV problem, i feel that the problem is internal of the transmission, i would book a test and report with a qualified transmission specialist as they will have all the special tooling and test equipment needed to diagnose this fault correctly.
mark (mhpautos)
Aug 1, 2009 at 2:10 PM
