Replace Cabin Air Filter?
60,000 MILES • 6 CYL • FWD • AUTOMATIC
HAL47
Jul 29, 2009 at 5:12 AM
DOCFIXIT
  • 18,828 POSTS
Locate door at evaporator housing slide door to rear till it engages opened stop.Pull downward .pull out filter (note: This is an option and some cars don't have a cabin filter.)
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_7.jpg
https://www.2carpros.com/articles/how-to-change-an-air-cabin-filter Please let us know if you need anything else to get the problem fixed.
Jul 29, 2009 at 5:29 AM
MOOTI
how to replace cabin filter on Dodge Caravan SE 4 Cyl
Mar 21, 2018 at 4:46 AM (Merged)
SATURNTECH9
  • 30,869 POSTS
There you go.
STEVEN BAYRUNS
Air Conditioning problem
2004 Dodge Caravan 6 cyl Front Wheel Drive Automatic 54,000 miles
How do I change the cabin filter ? It has two zones . It has a 3.3 liter 6cyl.
BMRFIXIT
  • 19,053 POSTS
Here is what I found to show you how to replace your cabin air filter. 1.Locate the air filter door on the bottom of the lower evaporator housing just outboard of the passenger side of the instrument panel center stack. 2.Slide the air filter door latch toward the rear of the vehicle until it engages the opened stop on the door. 3.Pull the air filter door latch straight downward to disengage it from the air filter opening of the lower evaporator housing. 4.Use your fingers to reach through the air filter opening of the lower evaporator housing far enough to grasp the air filter. 5.Pull the air filter straight down and out of the evaporator housing.
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_293.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic2_135.jpg
Here is a guide that should help as well. https://www.2carpros.com/articles/how-to-change-an-air-cabin-filter Please let us know happens so it will help others.
KKIBODEAUX
2008 Dodge Caravan 6 cyl Front Wheel Drive Automatic 55000 miles
how to change cabin filter in dodge grand caravan
Mar 21, 2018 at 4:47 AM (Merged)
TOOOMANYTOYS
  • 513 POSTS
Its necessary to remove glove box door. Once removed there are two tabs you press in an the access door comes off. Replace filter install cover and reattach glove box.
SIM3MI
  • 5 POSTS
ive seen the info in the filter box. mine doesnt have clips on the bottom. it is a solid box
PROAUTOTECH
  • 288 POSTS
I've seen a lot of chryslers that don't have clips, they have slides. See if there's one or two square shaped or C shaped pieces of plastic that will slide about half an inch. Once you slide them it should open. If that's not the case, look straight up for phillips head screws. Let me know.
SIM3MI
  • 5 POSTS
ty, i will try looking for screws. i have looked and looked [ and im not the only one] no clips. ty again.
PROAUTOTECH
  • 288 POSTS
http://www.youtube.com/watch?v=uL-qmrBtjS4
Here you go buddy
SIM3MI
  • 5 POSTS
i thank you, but ive seen that.i have 2003 dodge grand caravan , sport..... and that is not the way mine works....I HAVE NO CLIPS.... it is one piece. must be screws sraight up i cant see. its been 6 mos. and many people and i cant find the answer for a filter aaaaarrrrrgggggg! i really do thank you for trying to help............ screws straight up or dealer time...... ty again.
EDHOYO
Interior problem
2001 Dodge Caravan 6 cyl Front Wheel Drive Automatic 104000 miles
I need to know how can i replace the cabin air filter
PROAUTOTECH
  • 288 POSTS
I haven't worked on that model, but I'm extremly curious. Have you considered the possibility that in goes in under the hood, or under the trim below the windshield by the wipers? Please let me know when you figure it out.
IMPALASS
  • 3,112 POSTS
Hello - Removal
https://images.2carpros.com/forum/automotive_pictures/248015_Air_1_1.jpg
Locate the air filter door on the bottom of the lower evaporator housing just outboard of the passenger side of the instrument panel center stack. Slide the air filter door latch toward the rear of the vehicle until it engages the opened stop on the door. Pull the air filter door straight downward to disengage it from the air filter opening of the lower evaporator housing. Use your fingers to reach through the air filter opening of the lower evaporator housing far enough to grasp the air filter.
https://images.2carpros.com/forum/automotive_pictures/248015_Air_2_1.jpg
Pull the air filter straight down and out of the evaporator housing. INSTALLATION Note the "Airflow" directional arrow imprinted on the foam seal around the frame of the air filter. This arrow should always be oriented towards the center of the vehicle. With the air filter "Airflow" arrow properly oriented, carefully slide the filter fully upward into the evaporator housing through the air filter opening. With the latch still positioned against its opened stop, reinstall the air filter door onto the lower evaporator housing air filter opening. Slide the air filter door latch toward the front of the vehicle until it hits the closed stop on the door.
SIM3MI
  • 5 POSTS
i will check it out and let you know. ty
PROAUTOTECH
  • 288 POSTS
any luck? I'm still curious
TONY1667
How to Change an Air Cabin Filter to a dodge caravan 2005
DOCFIXIT
  • 18,828 POSTS
Locate air filter door pass side below evap case see diagrams
DOCFIXIT
  • 18,828 POSTS
diagram
TONY1667
thanks.
GKLINT
Interior problem
2005 Dodge Caravan 6 cyl Two Wheel Drive Automatic 105 miles
how to replace
BMRFIXIT
  • 19,053 POSTS
Locate the air filter door on the bottom of the lower evaporator housing just outboard of the passenger side of the instrument panel center stack. Slide the air filter door latch toward the rear of the vehicle until it engages the opened stop on the door. Pull the air filter door latch straight downward to disengage it from the air filter opening of the lower evaporator housing. Use your fingers to reach through the air filter opening of the lower evaporator housing far enough to grasp the air filter. Pull the air filter straight down and out of the evaporator housing. Installation NOTE:Note the airflow directional arrow imprinted on the foam seal around the frame of the air filter. This arrow should always be oriented towards the center of the vehicle. With the air filter airflow arrow properly oriented, carefully slide the filter fully upward into the evaporator housing through the air filter opening. With the latch still positioned against its opened stop, reinstall the air filter door onto the lower evaporator housing air filter opening. Slide the air filter door latch toward the front of the vehicle until it hits the closed stop on the door.
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic2_208.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic3_99.jpg
RCR
Does my 2005 dodge grand caravan have a cabin a filter
  • 110,248 POSTS
Yes, it should. It will be located under the dash behind the glove box. You need to remove the glove box door to access.
SIM3MI
  • 5 POSTS
change ac cabin filter
HMAC300
  • 48,601 POSTS
here is apic, make sure to wear safety glasses so you don't get crap in yuor eyes........it's pretty self explanatory
CONFUZED
I need/want to change the cabin air filter for my van and i can't seem to find where it goes. It is a 04 Grand Caravan 3.3L V6 Canadian Model. Can you help?
BMRFIXIT
  • 19,053 POSTS
Not all equipped with cabin air filter
CONFUZED
The area where the air filter door should be is smooth. there is no latch, but i understand where you are describing. thanks for the quick reply though.
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_549.jpg
JFFRUGE74
2003 Dodge Caravan 6 cyl Front Wheel Drive Automatic 174000 miles
How to change cabin air filter
  • 110,248 POSTS
On your vehicle the filter is located under the dash. If I recall, it is behind the glove box area. There are a couple clips that come open and then you can remove the old one and replace it.
