2006 Dodge Caravan Automatic Transmission shifting problems
MILOTOO
Air Conditioning problem
2006 Dodge Caravan 6 cyl Front Wheel Drive Automatic
I was reading a posted problem a fellow had with a 96 Caravan/Voyager. Transmission wouldn't shift past second gear. Response from a Tech was that it was in Limp-In-Mode. Possibly the Input or Output Sensor.
Excelent advice. Great picture of the locations on the transmission. Wish I had written down the Technitions name, he deserves a pat on the back.
What I found on my vehicle with the same problem.
Speedometer started swinging from hiway speed of 60 to 30 and back to 60, then 60-0-60. At trip end I parked but when on the go again it would shift to 2nd gear only. I have quite a bit of mechanical experience (60 years) but the electrically controlled automatic transmissions are mew to me. After reading the Techs great reply I ordered the two sensors. $16 input and $17 output at NAPA. Four hours trying to get to the input sensor from behind the radiator, up from behind the bumper, or thru the left wheel well left me fustrated and scratched and scarred. I did manage to touch the back end of the sensor with my finger tip.
Next day the battery and box were removed and the playing field leveled by removing the radiator hose from the back of the engine and tying the wire bundles back out of the way. Clip securing the plug to the sensor was released with a LONG screwdriver and the sensor removed using a 1" standard socket with reducer and a 3/8 u-joint and 3 inch extension. Output was readily accessable thru the left wheel well opening.
Vehicle now drives like new.
Thanks for your great post.
Just thought I would pass along the info on how to accomplish an impossible problem.
Oct 7, 2009 at 10:49 PM
BMRFIXIT
  • 19,053 POSTS
Thank you for the replay and the detailed instruction
as you found out the difference between the 1996 and 2006
Oct 7, 2009 at 10:59 PM
MILOTOO
When I wrote the question I clicked on the 1996 and the computrer put in 2006, I clicked Transmission and the computer wrote Air Conditioning. Got any idea why a computer will never replace a mechanic gor car fixing?
I also wrote to your website home page with a request (or a suggestion) for a system where a crotchetry old man could send a Money Order for donations instead of using a credit card. I am probably like a multitude of other older people who won't spread their card number around the 'Net. I don't know about the Pay Pall either.
If each Tech would have a drop box or the like (not your personal home address for security reasons) where donations could be sent, I am sure it would increasde your finances. Count me in for a fifty if it can be sent by slow mail
Respectfully,
Milo Taylor
SE Georgia
Oct 9, 2009 at 12:33 AM
BMRFIXIT
  • 19,053 POSTS
Thank you for the suggestion and I do agree with you there should be a way that you can sent donation the old way (by slow mail )
I will address the point with the accountant
thank you again
Oct 9, 2009 at 1:38 PM
