2005 Dodge Grand Caravan No Front Air
SIRGARB
The front blower does not blow air on my 2005 dodge Grand Caravan 65000 miles 3.8. the rear works. I pulled the resistor but it looks good. fuses are good. ??????????? how can I test the resistor
Feb 26, 2007 at 6:24 AM
LYTN_J
  • 19 POSTS
I would check fuse 10, 40 amp, if the fuse looks good, check one of the terminals where the fuse plugs in, with the heater controls turned on, one of the terminals should be hot, is it?
If it isn't hot, that leads back to the front blower motor relay.
Feb 26, 2007 at 7:18 AM
BHUGG
  • 157 POSTS
Many cars have 2 fuse boxes. Make sure that you check BOTH. Look for one under the hood. That is where the fuse that "@#$%" told you about.
There is also ususally, for the blower, a relay that is usually in the fuse box under the hood. That might have failed also.
Feb 27, 2007 at 2:18 AM
Suggested Repair
Check both fuse boxes, especially the under-hood box, for the 40-amp fuse 10. With the heater controls on, confirm that one fuse terminal has power. If it does not, test or replace the front blower motor relay in the under-hood fuse box.
Conversation Summary
The front blower on a 2005 Dodge Grand Caravan does not blow air, while the rear blower works. The resistor and visible fuses appeared good. Advice was to verify fuse 10 in the under-hood fuse box, check for power at a fuse terminal with the controls on, and inspect the front blower motor relay if power is missing.
