2005 Dodge Grand Caravan Power Sliding Doors are stuck
SLCJHC
2005 Dodge Grand Caravan, 79,000 miles. Just last week the passenger side power sliding door started sticking. It will open with the inside button about 4-5 inches then get stuck. If the door is open, it will close to about 4-5 inches from the frame and get stuck. We have checked the track and there is nothing hindering it. Any suggestions?
Aug 20, 2007 at 5:46 AM
2CARPRO JACK
  • 11,533 POSTS
Could be the motor is going out and it draws too much for the system, like a window that will only go part way up or down
Aug 22, 2007 at 12:37 AM
SLCJHC
It always gets stuck in the same place, coming or going. If we push it past that spot, the motor will kick in and go until the door is totally opened or totally closed. When I push the button to open, it goes to the spot, stops and clicks. If we push it just a little past the spot & then push the button again, it opens all the way. Ditto for closing. I don't think the motor is going, but I can't figure out what it could be.
Aug 22, 2007 at 7:58 AM
2CARPRO JACK
  • 11,533 POSTS
If it is always in the same place, something is keeping it from sliding freely, try looking closer or lubing the track
Aug 22, 2007 at 11:05 AM
ZARMOX
I have the same problem. When I open or close the door manually, it slides freely so there is nothing jamming the track. I also tried lubing the track - the problem still persists.
Dec 7, 2007 at 2:03 PM
CRWILL
Did anyone figure out what this problem was? My 2005 Dodge Grand Caravan is having the exact same issue.
Jan 25, 2011 at 6:20 AM
