2005 Dodge Caravan Uneven front pad wear left to right
2005 DODGE CARAVAN
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
SIMONHAMPSON
front brakes wear out in 1 year. right side worn almost to metal left side still has 50%. each pair of pads (left or right) are wearing evenly as a pair. but the right side wears much faster than the left. replaced rotors already and callipers are not sticking. However the brake system seems to be applying more pressure to the calliper on right side than the left. we determined this by applying steady braking pressure at the pedal and then attempted to turn each wheel with a breaker bar. the right side was much harder to turn. any suggestions?
Simon
Dec 9, 2008 at 6:31 AM
ZACKMAN
  • 4,202 POSTS
Start by bleeding all calipers and wheel cylinders (if applicable). Re-grease your caliper bolts. Seems that you have contaminants in the line that prevents fluids from going to the left front caliper.
Mar 1, 2021 at 2:21 AM
