change the transmission fluid
2005 DODGE CARAVAN
77,000 MILES • 6 CYL • FWD • AUTOMATIC
SANNYM370
Can you tell me how to change the transmission fluid in my van? I don't know where the drain is.
Jul 18, 2008 at 10:19 AM
OBXAUTOMEDIC
  • 3,711 POSTS
This video shows the job being done on a similar car but the process is the same with diagrams below for your car. https://youtu.be/NUOBl4bqtss Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car. https://www.2carpros.com/articles/how-to-service-an-automatic-transmission Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.Can you tell me how to change the transmission fluid in my van? I don't know where the drain is. This video shows the job being done on a similar car but the process is the same with diagrams below for your car. https://youtu.be/NUOBl4bqtss Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car. https://www.2carpros.com/articles/how-to-service-an-automatic-transmission Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
https://images.2carpros.com/forum/automotive_pictures/188069_transdrainpan_1.jpg
May 20, 2021 at 8:51 AM
