2005 Dodge Caravan sluggish
54,000 MILES • 6 CYL • FWD • AUTOMATIC
MAJP_99
When I drive uphill the car feels suggish. I push down on the gas and the car feels like its not moving much.
Jul 19, 2010 at 3:53 AM
  • 75,988 POSTS
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Jul 19, 2010 at 3:26 PM
