2005 Dodge Caravan Sensor problems
2005 DODGE CARAVAN
105,000 MILES • 6 CYL • FWD • AUTOMATIC
ORTIZI3
The problem is crankshaft sensor and camsahft sensor misaligment.
Both sensor are new, but the problemen persists.
The computer is new and exsaust catalitycs is in
good conditions.
The car doesn't exceed 2500 rpm.
Jul 29, 2010 at 3:30 PM
Check the fuel pressure if its within specs if okay test the throttle position sensor , manifold absolute pressure sensor/intake air temperature sensor, also the knock sensor could be retarding the ignition timing
Jul 30, 2010 at 6:35 AM
