2005 Dodge Caravan Rear Turn Signal
61,250 MILES • 4 CYL • 2WD • AUTOMATIC
REPAIR317
How do you remove the rear light casing to replace the light?
Nov 2, 2008 at 1:21 AM
JPAM
  • 307 POSTS
not 100% but lets start with your rear gate open and there should be 2 screws.(more than likely phillips head screw driver is needed.) Remove screws, and pull rear lens out.(think there is some kinda tabs that keep the other side of that lens in place) Unhook wire for the light that needs replacing, replace it and put it back together...
Well I hope thats how yours is set up...
good luck
JesseS
Nov 2, 2008 at 1:36 PM
