2005 Dodge Caravan power windows
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
TINAMAY
my drive side power window will not work. I checked the owners manual and it said the fuse is located under the instrument panel near the steering wheel. Do I have to remove anything to get to the fuse?
Sep 6, 2008 at 9:21 AM
BMRFIXIT
  • 19,053 POSTS
Just to save you time
if fuse to be blown then the passenger side will not work
most common :
window motor and regulator
good luck
Sep 6, 2008 at 11:33 PM
