2005 Dodge Caravan Power door locks
52,000 MILES • 6 CYL • FWD • AUTOMATIC
FOXLEAR
I have a 2005 Grand Caravan, and I cannot get the power door locks to operate, either with the remote key or with the power door lock switch on the driver's side door. I went to look for a fuse, but there is no indicator on the inside lid of the fuse box that tells me the fuse for the door locks.
Dec 2, 2008 at 2:26 PM
  • 110,248 POSTS
If you have the owner's manual it will have the info. If not, check to see if any of the fuses are bad. Replace as necessary.
If there are no bad fuses, you will need to remove the door panel to see if there is power to the switch. Also, checked for damaged wires going through the door.
Nov 5, 2018 at 9:26 AM
MOMMYCAT2008
I'd read in another forum to disconnect the battery cable and pull the BCM fuse. The system should then reset itself. Seems a lot of ppl, myself included are having this same issue. I haven't tried this fix yet, but I will tomorrow. Sounds easier than pulling off the door panel, which may well be necessary, but I will try this first!
  • 110,248 POSTS
Hi:
Give it a try and let me know how it goes.
