2005 Dodge Caravan P0016 Cam & Crankshaft sensor wiring
107,000 MILES • 6 CYL • FWD • AUTOMATIC
VICTORY89
I am getting two P0016 codes. It is very short on power, isn't shifting at the right rpm's, is jerky when it does finally shift. I've replaced the cam and crankshaft sensors and it didn't help. I am going to check the wiring now. My question is what and where should I be checking? and what volts, amps, etc.....
Oct 26, 2009 at 2:14 PM
BMRFIXIT
  • 19,053 POSTS
Reports of cracked flex plate is very common and suggest checking that 1st
Oct 26, 2009 at 10:53 PM
VICTORY89
Why would I want to pull the transmission before checking the current going to and from the sensors??
Oct 28, 2009 at 7:53 AM
