2005 Dodge Caravan Malfunction Indicator Light
108,000 MILES • 4 CYL • FWD • AUTOMATIC
JPRILEYJR
My MIL has been on for a few drives, off for a few drives, etc. I had oil, filter, air filter changed, figuring it could need a tuneup. After reading on here, I figured out how to determine the malfunction code and it is PO301, which says engine misfire detected. What does this mean? Is it important? What should I do to resolve the issue?
Nov 1, 2010 at 8:08 AM
  • 110,248 POSTS
What that code indicates is the #1 cylender is misfiring. Has the vehicle ever been tuned up? Have you ever replaced ignition wires, plugs, cap...?
Nov 1, 2010 at 12:48 PM
JPRILEYJR
No, I have not had a tuneup. I have not had plugs changed, etc.
What exactly should I ask for when I go to the repair shop?
What should I expect it to cost?
Nov 1, 2010 at 2:07 PM
  • 110,248 POSTS
Well, since only the #1 cylender is misfiring, I would start with a basic tune up. Have them replace the spark plugs and wires. That should take care of the problem unless there is an injector issue. However, usually, that has an affect on more than one cylender.
For a 4 cylender, I can't imagine the cost would be more than 80 to 100 dollars for plugs and wires.
Let me know what you find.
Nov 2, 2010 at 12:30 AM
JPRILEYJR
Hey Joe,
Had the spark plugs and wires changed and not only is the indicator light off, but the engine is much quieter, too.
Thanks so much!!
Nov 2, 2010 at 4:30 PM
  • 110,248 POSTS
Great! I'm glad you got it fixed. Usually, the easiest problems cause the most trouble. I hope I was close on the cost, but based on where you live, it may have been off.
Let us know if you have questions in the future, and thanks for using 2carpros.com.
Nov 3, 2010 at 12:36 AM
JPRILEYJR
So Joe,
Caravan ran well for a few weeks, and NOW the malfunction indicator light is BACK...same code PO301. Since the plugs and wires have been changed, what would I do next?
Nov 12, 2010 at 9:58 AM
