2005 Dodge Caravan front blower fan
2005 DODGE CARAVAN
80,000 MILES • 6 CYL • FWD • AUTOMATIC
KPOIRIER1125
2005 Dodge Grand Caravan SXT
Front blower fan doesn't work on any setting. Rear blower and a/c works fine. I believe a/c in front is ok too, since cold air will trickle out when I'm driving at faster speeds.
If, as I believe, the problem is with the blower, what do I check and how do I check it to confirm? How do I replace the resistor and/or the motor?
Jun 6, 2008 at 2:55 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:fc95950eb6="kpoirier1125"]Interior problem
2005 Dodge Caravan 6 cyl Front Wheel Drive Automatic 80000 miles
Thank you.[/quote:fc95950eb6]
Ok, It is most likey the Blower Motor Resistor, it is located in the duct work under the passenger dash very easy to replace. And Unfortunatley you are probably going to the dealer for the part.
Jun 8, 2008 at 3:47 PM
SAWDAWG63
[quote:60010b8d96="kpoirier1125"]Interior problem
Thank you.[/quote:60010b8d96]
May 29, 2009 at 3:51 PM
JGGARZA
The front blower power module may need to be replaced. Easy to get to under the dash board (passenger side for Pacifica). Save some money and buy it used at a junk yard.
Feb 21, 2011 at 10:15 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Hey jggarza
Your a couple years to late on this question. It was post June 6th 2008.
Feb 24, 2011 at 7:08 PM
