2005 Dodge Caravan door mirrors
2005 DODGE CARAVAN
60,000 MILES • 6 CYL • FWD • AUTOMATIC
FIREMANKEN
I need to replace my right side door mirror. How does it come off to replace. (the whole mirror is broken off, hit the garage door.
Thanks ken
Feb 23, 2010 at 8:51 AM
CARADIODOC
  • 34,381 POSTS
Three recessed nuts inside the door by the base of the mirror. Have to remove the entire door panel on '95 and older vans. You might have a small triangular panel that comes off separately, can't remember.
Practice on a used mirror in a salvage yard. That's an easy way to learn how to remove your door panel without damaging the mounting tabs.
caradiodoc
Feb 25, 2010 at 9:28 PM
HAHNY1
  • 75 POSTS
on 96 and newer the mirror is not attached to the door. if you open your door you should be able to see the screw or screws in the door jam
Mar 6, 2010 at 11:32 AM
