2005 Dodge Caravan door locks will not function
37,000 MILES • 6 CYL • FWD • AUTOMATIC
RICHARD J
door locks will not function, neither switch on driver door or passenger door will lock or unlock the doors, remote does not either but will activate horn and lights. I recently replaced driver side mirror, locks did not operate while wires to mirror heater were disconnected but did work when mirror heater wires were held together. Locks functioned for a day after new mirror was installed with wires connected to heater leads.
Jan 9, 2008 at 7:43 AM
BMRFIXIT
  • 19,053 POSTS
[quote:1f4ec70db8="Richard J"]Electrical problem
2005 Dodge Caravan 6 cyl Front Wheel Drive Automatic 37000 miles
door locks will not function, neither switch on driver door or passenger door will lock or unlock the doors, remote does not either but will activate horn and lights. I recently replaced driver side mirror, locks did not operate while wires to mirror heater were disconnected but did work when mirror heater wires were held together. Locks functioned for a day after new mirror was installed with wires connected to heater leads.[/quote:1f4ec70db8]
check fuses and relays
fuses 1st
Jan 9, 2008 at 11:08 AM
WILDIE
I have the same problem with my 2005 Caravan.
I have found that there is TSB instructing thatthe Body Control Module must be re-flashed!
My mechanic cannot do this, so i'll be taking it to Dodge dealer.
Sep 9, 2008 at 9:26 AM
