2005 Dodge Caravan Dashboard going haywire
70,000 MILES • 6 CYL • FWD • AUTOMATIC
WVUTIM
My entire dashboard including my radio, speedometer and rpm gauge flashes and flickers on a constant basis. What could be causing the problem? I have ahd my battery checked out and it tested fine. I don't seem to lose power to the engine when this happens. I am very concerned it could completely fail and stall. I need some serious help with this!
Nov 19, 2008 at 12:55 AM
ZACKMAN
  • 4,202 POSTS
The only common part to all of your accessories is the body control module, located at behind left side of dash. You need to remove the gauge cluster to gain access to it. Check the wiring harness, making sure it makes good, tight connection.
Nov 19, 2008 at 2:06 PM
