2005 Dodge Caravan code 480
150,000 MILES • 6 CYL • FWD • AUTOMATIC
ARTICUSBLUE
I have a check engine light code 480. I checked the fuse in the ipm and found fuse blown. replaced and the check engine light is still on but the fuse has not blown again. I am having trouble finding the rad fan relay and the power control mod that controls the fan relay
Jan 2, 2010 at 3:12 AM
  • 110,248 POSTS
The relay is at the top of the left front frame rail. Here is a picture:
https://images.2carpros.com/forum/automotive_pictures/249084_fan_3.jpg
As far as the PCM, it is located in the left front of the engine compartment. Here is a picture:
https://images.2carpros.com/forum/automotive_pictures/249084_PCM_1.jpg
Let me know if this helps. Joe
Jan 2, 2010 at 7:38 AM
ARTICUSBLUE
Hi Joe,
I tried to reply last night but the page closed. The 1 st pic has helped me find the rad fan. The second pic does not look like my motor. i will put on the lift and look for the power control mod. Are there different 3.3 6 cyl motors?
Thanks,
Rob
Jan 3, 2010 at 5:35 AM
  • 110,248 POSTS
Hi:
The is only one 3.3L. What looks different?
Jan 3, 2010 at 6:20 AM
ARTICUSBLUE
For the piece on top that has the 3.3 stamped it is a solid square shape. I will proceed. I was thinking there may have been other versions made. Thanks for the help. I will try and leave positive feed back.
Thanks,
Rob
Jan 3, 2010 at 2:20 PM
  • 110,248 POSTS
Thanks for the positive feed back. Let me know how things work out or if you have other questions, let me know.
Thanks for using 2carpros.com and take care of yourself.
Jan 4, 2010 at 3:33 AM
